Good evening,
has anyone ever controlled a Fibaro wall-plug with a toogle Switch, from Home Remote?
I tried all possible values without success.
How to switch it ON/OFF?
Good evening,
Ok, unfortunately you didn’t tell us which commands you have tested, “All” is not a reliable indication
This is what I found on the net:
http://[IP address of the controller]/api/callAction?deviceID=[ID of the wall plug]&name=toggle
I don’t have Fibaro but I might be able to help with the toggle function. Please post a screenshot of what you have tried so far in the designer.
347 / 5 000
It is in the “Value” field that I tested on, off, true, false, …
None of my tests worked.
On the other hand, if I address a fibaro lighting module, it works perfectly with the values 0 and 99.
I think that the wallPlugs respond to a different command, but which one?
That is the question!!!
See the screenshots.
Ok, now I understand your question.
Turn On:
turnOn
Turn Off:
turnOff
Toggle (Switch On/Off):
toggle
Dim (if the Wall Plug supports this function):
Brightness Value 0-99
Commands are case sensitive
