Hello Guys
well done with what seems a great product, although a little daunting at first
I was going to consider roomie remote, but not impressed at all and very vey unhelpful, very very rude, very very expensive, very very limited, very very buggy. So not ticking many boxes for me.
I have a home network that consists of various VLans from My Cisco ASA5506 router. I have Assigned VLAN2 as my media network, all TVs, Media Players, AV, Atlona Matrix Switching are on this subnet 192.168.2.x and so are my Wifi Access points to allow communication from iphone and ipad etc.
I can confirm I have various aps and can access webpage on the iphone to the hardware that allow control over this ip range 192.168.2.x
I am also thinking of purchasing the global cache ethernet to IR or wifi to IR just to add IR compatibility
but understand the limitations that IR is only one way/one direction
and its always best to access equipment via direct ethernet.
So wanting to start with controlling my ATLONA AT-UHD-PRO3-88M I can control it in various ways
- this can be controlled via HTTP I can access a web page and control it
- RS232 which I have linked up to the laptop and fired commands at it
- Telnet again used Putty terminal and issues commands
- I/R infra red standard remote control (one way)
so above I have a few ways to control this wonderful box
sadly under devices in your software there is nothing for Atlona ?? lets hope there will be one day soon
so I have to now figure out how to send commands over my network from the buttons in designer,
the ATLONA AT-UHD-PRO3-88M is at 192.168.2.2
If enter this in to my web browser i get the atlona webserver page
If I telnet to 192.168.2.2 I can issue commands via telnet
If I want to use RS232 I think I would need to purchase a Global Cache ethernet to RS232 pack
So is there anyway to send commands from buttons directly out over the LAN to my Atlona box obviously the designer software does NOT offer ATLONA as my device is not there
I also have a Dune media Server that I would like to control, I have the dune remote control app on the phone but would be nice to custom design in your software along with other devices.
if I was to use an packet sniffer could I scan the codes from the dune app to 192.168.2.80 (dune media player) and see when I press various button in the dune iphone app for various remote buttons what code is sent ?
I also design embedded electronics using ARM processors, I would be great if I could design in your software and then interface it via ethernet ip address to my hardware, again similar to what I want to do above with my Dune and Atlona AV kit
is any of this possible
I look forward to hearing more about you great product
Thank you in advance
John
