Alexa voice service HELP
Hello i try to set a button in home remote designer to trigger a alexa command. I dont know how. In the app itself it is pretty easy. Also i managed to set buttons for smart life devices. When i try to set a alexa command what should i do Please help
I don’t know if this helps (or is even correct). However, I understood that you need to type the actual command as it would be spoken in the event.
An explanation on how that works as well as an example was shared here. Take a look at that & then let me know if you are still having trouble.
Thanks for the response. I figured it out. I have one more question although. Is it possible to add an alexa trigger to play spotify on a specific echo device or open spotify on the tablet that i use for home remote?
