Hi Bill
We are installing Fibaro systems in houses, so for me is essential to be able to create dahsboards as quickly as possible. We can’t spend days in the customre’s houses just for playing with dashboards.
Its very cost ineffective.
So in general a customer with a larger system has more than 200 devices in their home. Sometimes more than 300,400.
That measn for me that I need to rewrite all these devices names, select the corresponding tiles to them,
etc.
This is so time consuming that i stopped to work with it. However if there would be some mechanism, that allowes me to define in some settings file or somewhere, what would be the default Tile for each device type, then when I am pulling in Fibaro devices, it would set their tiles correspondingly…
EX
Device Types Default Tiles
Switch MySwitchTile.xaml
Light MyLightTile.xaml
etc
And also, a big problem is the naming. In case of fibaro HR pulls the room names and put them together with device names. These complex names become very long, so we need to go one by one and rename them somehow to let them fit into little tiles.
If you could separately pull room names into some property of the device, and we can catch these names like @Device.RoomName that would be very good, so we could link these names into some labels, and kinda split into two labels the naming of the device.
EX
Livingroom
Main light
All these things would reallyn help a lot in our work, and would meant ofcourse new customers for you, as we always buy HR license when we install Fibaro and a Dashboard is needed.
If my approach is unsolvable, i am opened to any help that can speed up a little bit the integration of Fibaro devices. (and devices in general)
