Fibaro Home Center Lite
Hi All, is it possible to connect The Home Remote to Fibaro Home Center Lite?
Yes. The Home Center Lite uses the same API as the HC2. Select HC2 when you link Fibaro to Home Remote.
Thank you, Bill! And is it possible to control it remotely? It sees my devices only on wifi at home. What kind of ip address should I set to make it possible?
Fibaro has yet to release a remote access API. You’ll have to set up a port forwarding rule in your router if you want to access it remotely. Then you can use your public IP which is accessible anywhere.
