Home remote designer "This application cannot be run on your pc."
Hello,
The home remote designer (version 4.5.0.0) no longer opens in windows 10 32 version 21H2.
When opening the home remote designer, windows says “This application cannot be run on your pc.”
Three days ago everything was working fine.
I assume you have tried rebooting.
What was done to the system in those three days?
Can you try the version in the Microsoft Store 4.5.1.0?
You will also need to install .NET 6 Desktop Runtime if you haven’t already installed it.
Hello,
I installed from Microsoft Store version 4.5.1.0 and reinstalled .NET 6 Desktop Runtime. Nothing has changed, Windows still says “This application cannot be run on your computer”.
PC rebooted several times.
I would like an answer to my problem.
thank you
Have you tried Googling the error?
It could be possible that the Designer only works on x64 now. It should work on both but I myself have not tested the latest build on x86. Do you have a 64-bit machine you can use?
