Are you using HTTPS for both internal_url & external_url?
The Home Remote uses both URLs. I think in most cases, systems use standard HTTP for internal/local access. If you are trying to link Home Assistant on your local network, Home Remote should be using your internal_url. It almost sounds like you’ve got HTTPS enabled on your internal_url.
