Life 360 Location Data
I am new to Home Remote, but so far love the control it gives.
I have recently tried to add my Life 360 location data that is connected through my Hubitat hub, but I can’t seem to get any sensible data out of it.
I have noctied that within the designer the Life360 device is being detected as a ThermostatSwitch !
Is there any way to change this and get it detected as a tracking device ?
You can change the templates that were assigned to the device. You can even create new ones if there isn’t a template that you’d rather use. By default, I believe the app will assign ThermostatSwitch when a device has Switch & TemperatureMeasurement capabilities. Again, you can change that though. The Designer gives you that option. The apps alone do not.
I can see that I can change the templates, but what about adding the capabilities ?
Do I just type them into the Capabilities box of the device in the designer ?
Or am I going about this the wrong way ?
You can’t add capabilities. The Home Remote reads them from Hubitat. It will add all that are supported. You can however add attributes.
Thank you so much, it looks like I have got it working now and it’s showing location data.
Just need to send someone out to check it’s working !
