Attached is a Plugin for a Monoprice Motorized Projector Screen. It’s compatible with part numbers 7337, 7338, 7951, 30451, 30452, 30453
https://www.monoprice.com/product?p_id=30453
This setup also requires an IP to Serial converter so it can be controlled over a standard network connection. You can use a product like the Global Cache IP2SL.
https://www.globalcache.com/products/itach/ip2slspecs/
To install the plugin, use the Plugin Import utility in the Designer. The import process will ask you for the IP Address & Port of the IP to Serial converter. The default port for Global Cache serial converters is port 4999.
Here is the plugin code:
MonopriceProjectorScreen.plugin (1.4 KB)
plugin.Name = "MonopriceProjectorScreen";
plugin.PollingInterval = -1;
plugin.DefaultSettings = { "Host": "192.168.1.100", "Port": 4999 };
var deviceId = "1";
var socket = new TCPClient();
var commands = {
"ScreenUp": [0xFF, 0xEE, 0xEE, 0xEE, 0xDD],
"ScreenStop": [0xFF, 0xEE, 0xEE, 0xEE, 0xCC],
"ScreenDown": [0xFF, 0xEE, 0xEE, 0xEE, 0xEE],
if (attribute != "MediaCommand")
throw "Invalid attribute";
var command = commands[value];
if (!command)
throw "Invalid command";
socket.send(command);
socket.connect(plugin.Settings["Host"], parseInt(plugin.Settings["Port"]));
var device = plugin.Devices[deviceId];
if (device != null) {
device.SupportedMediaCommands = Object.keys(commands);
function onDisconnect() {
socket.close();
var device = new Device();
device.Id = deviceId;
device.DisplayName = "Projector Screen";
device.Capabilities = ["MediaControl"];
device.Attributes = [];
plugin.Devices[deviceId] = device;
