Problem with Danfoss living connect radiator valves
@APPA Both of your issues will be fixed in the next release.
#1 is most likely related to the same issue I reported a couple days ago.
#2 is a new bug I wasn’t aware of until now. I have found & fixed the issue. It’ll work correctly in the next release.
Thanks a lot. I`ll wait for the next release.
The 3.12.1 release with the changes is available to test.
Hi
I’ve just tested this and it is working now with only one issue.
If you are in the Home Remote app and you change your thermostat from say 10 to 23, now the app will remain displaying 23.
You can leave the thermostat device and navigate around to other areas of the home remote app and then go back in to the thermostat device and its still at 23 setpoint, even though the thermostat is still waiting to wake up to accept the new command.
So this works and it is fixed.
However if you switch to another Android app on your phone and then switch back to Home Remote, then the setpoint value goes back to the current / old value of 10.
Correct, switching apps will force a full refresh & show the value in the JSON. I’m not sure if I want to change that behavior.
I have checked the new version, and the opeation is OK for me.
Thanks a lot.
