Setting Fibaro QA variable with HR slider
Hi,
Does anyone know how to set a Fibaro QA variable from HR?
I figured out that QA buttons in Fibaro can be controlled from HR by uiCallbacks.button_name
but couldn’t find a way, how to set a QA variable.
I have a variable Duration in my Fibaro QA device, but when i bind it directly to HR slider i am getting
an error like:
Class does not have setQuickAppVariables.Duration function defined - action ignored
Any help would be appreciated…
You need to add an Attribute to your device object called “uiCallbacks.XXXX” & set that variable. Here’s an example:
Hi Bill
I know this example…that’s where i started…
Actually i have only a variable in Fibaro…its not connected to any button or slider…
It needs to be connected and handled by some element in Fibaro just to have that UI posiibility?
Sorry i dont really understand, how to achieve this…
Adding the atribute to my device didn’t help…
even the labels that worked before stopped working.
I suppose i cant use this ui.callback if i dont have any UI element in Fibaro which should set the variable there. Am i right?
If it is only a variable, couldn’t you just use the global variables Plugin?
Yes I could, but i saw in some topic that its way better to use QA variable, than global ones.
If I was using some UI element in Fibaro, than this should work in the way you showed ?
With the ui.callback call?
So actually we will bind a slider in Fibaro with a slider in HR right?
Thanks a lot
{how can I send you some gift or anything to compensate your time?}
Yes, it should. I myself have never tested it though. They aren’t selling the HC3’s here in the US yet. The only controller available here is the Home Center Lite.
You can send me a PayPal donation. There is a link on the website & that will go directly to me. Thank you very much!
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=3LLX85XBVHFJ2&source=url
I will do it…
Anyway, are you avilable for some work?
I am a coowner of a company, that is focusing on FIbaro and Hubitat installations, and
i would really like to hire you for some projects…
Are you interested ?
Sure. Definitely interested. Just let me know.
