Weather Widgets
Hi Bill,
How can I add a weather widget ?!
I’m trying to use web browser control but it’s not working :
Thank you again
Attached is an example showing how to load an HTML widget from weatherwidget.io
WeatherWidgetIO.hrp (6.7 KB)
The body of the HTML you can get from the WeatherWidget.IO website. The rest is standard. You can change the background to whatever you wish. I’ve got it set to #333333. The line “initial-scale=1.0” is something needed if you plan to run on iOS.
Thank you very much again Bill!!
