I have been using ImperiHome for many years but am now looking for a replacement for it as ImperiHome has now disappeared from the market.
When I was looking for a replacement, I found Home Remote which after a bit of testing seems to be a very competent replacement.
In Home Remote I have much greater opportunities to create my own design, ImperiHome was much more limited.
One of my demands was also that the program could handle Fibaro HC3 with devices, scenes and above all Fibaro’s new QuickApp’s.
In HC3 I have a QuickApp that controls a car heater (I live in cold Sweden). I want to be able to handle this QuickApp in Home Remote, just as I could in ImperiHome.
The car heater has 7 buttons for setting time etc., as well as a label that should show Departure time and Status.
But I have not managed to get either buttons or label to “talk to” HC3 QuickApp.
I then did a test and created the same app with data from a VD in HC2 that I also have. There, the car heater worked as it should.
Retrieving and displaying, for example, temperature data from HC3 was no problem, but it does not want to “talk” to any QuickApp.
So how do I get on with my QuickApp in HC3?
I found an example of a script required to start a scene, do I need a similar script to communicate with a QuickApp?
Can someone please, give me a push in the right direction.
And do I have to buy four licenses of Home Remote when I plan to use two Tablets and two mobiles?
